rear window problem
  • rear window problem
    got the inside of surf a bit water loged.since then the switch on inside wont opperate.had the switch out all the wires are on.any ideas?
    sigos85@hotmail.com
    Does the one on the tailgate work? If not, have you checked the fuses in the driver's footwell.
      Isnt he referring to the tailgate window?
      Trust your Hound.
        Yeah, Theres two switches for the tailgate. The key on the outside an switch inside.
        If the switch isn't working but all seems ok it could be that the switch is just duffed. But if the outside one isn't working either then its tailgate related.
          cheers freinds.
          the key opperates from outside.
          so u think its the switch?
          i will get mechanic to put electrodes on it see if theres power coming through.
          sigos85@hotmail.com
            have you checked the "lock" button??.... usually the most common problem!!
              i was gonna suggest that too, but it's really too obvious isn't it, I mean what kind of a daftie would ever do such a thing.............
              Alan
                LMFAO ME
