just bought some wheel arches off e-bay for my 94 surf the model with no arches, do i need some sort off rubber seal to fit against the body work or will clear sealant do the job.
arches
Not all.Originally posted by Scorpion View PostProbably get my head bitten off for this, but isn't a '94 SSRX without arches something of a rarity? I thought all the newer gen 2's had wide arches?
It is pretty rare.
But only t'other day we found a 3rd gen with 15" wheels on so nothing is impossible!!
This is what I would probably use....or something similar from B&Q or Screwfix
http://cgi.ebay.co.uk/Rubber-Car-Doo...1%7C240%3A1318
Could always get some tiger seal..
a member on here gave me a tube!! Its amazing stuff.
I think body shops use it to stick on all sorts. The Surf arches attach via fittings that are in the body. You probably wont have those fittings so getting them on might be awkward anyway.
A tube of tiger seal would fix all 4 arches on an take care of any kind of protective rubber.
no problem fitting to the underneath of existing arch using self tappers just need to seal against body ,will check out the tiger seal, thanks.Originally posted by RodLeach View PostCould always get some tiger seal..
thanks a lot mate ,hopefully i can shake off this man flue by then should i email b4 to get your address.Originally posted by stormforce View PostRobbie.I have got 4 arches on the breaker here with the rubber seals on still.If you want to come over at the weekend and take the arches off you can have the rubbers if you want them
you can ring me on 07974183876 before your ready to come over if you want and i can give directions then.If i can get the arches off beforehand i'll let you knowOriginally posted by robbie View Postthanks a lot mate ,hopefully i can shake off this man flue by then should i email b4 to get your address.https://www.facebook.com/groups/henpals/
ok will phone on friday,pity i didnt know about you before i could have bought the arches from you as i need to spray mine black or burgundy to match truck, the ones i have are for the trucks made without arches and wide mudflaps etc, do you know anything about the rear window motor i replaced mine a year ago working ok until this frosty weather the stopped completely .thanks for your help.Originally posted by stormforce View Postyou can ring me on 07974183876 before your ready to come over if you want and i can give directions then.If i can get the arches off beforehand i'll let you know
sure its not just frozen?Originally posted by robbie View Postok will phone on friday,pity i didnt know about you before i could have bought the arches from you as i need to spray mine black or burgundy to match truck, the ones i have are for the trucks made without arches and wide mudflaps etc, do you know anything about the rear window motor i replaced mine a year ago working ok until this frosty weather the stopped completely .thanks for your help.
....at least it is fairly unique.
