I know, I know......noob with all the questions.
...well I have looked through every faq I can find, and have googled until my ar5e has turned blue but have still not found a conclusion to my query.
This is a picture of my gear/transfer levers:
[IMG]
[/IMG]
In laymans terms, I would imagine that with the left hand lever in 4L and the 4wd button pressed on lever that will give me 4wd low gearing.
With the left hand lever in 4H and the 4wd button pressed that will give me 4wd high gearing.
With the left hand lever in 4H and the 4wd not pressed, that will give me 2wd high gearing.
....with me so far?....
This surf is a 3rd gen......where do the levers have to be to lock (or indeed unlock) the diff?...are any of those selections above locked?...I have only ever seen a green 4wd (4 little green wheels on axles) light on the dash....am I missing an orange "diff" light?
Obviously I should really go to a local mud pit or grass verge and try all the options out, but really haven't had the time (and large expanses of turf that you can tear up aren't that prevalent round here).
Thanks for your help.
[IMG]
