Vista question
  • Vista question
    Does the easy transfer wizard, (or whatever they've called it), in Vista work with the files generated by the XP files and settings transfer wizard?
      After the pm's i cant believe im about to give you advice an expect you to listen but...
      You need to put a cd-r or cd-rw in the draw of the vista pc. It makes up a drivers file that you place in the xp machine.
      That is what allows them to talk. I believe you can do it with a removable storage device aswell. Memory stick etc.
        Originally posted by BioHazard View Post
        I'm in the same boat. Never even looked at a Vista machine, (and have no intention of doing so if at all possible).
          The lapstop has vista .......user friendly .............trouble is i can't use it
            Ah, but did you read the question correctly? The specifics of how they work ain't the problem, (I already created the images and passed the cd on), but as to whether the Vista prog is backwards compatible is. I'm having to give phone advice to someone who isn't exactly at ease with P.C's, and I ain't never touched Vista.
            I can't believe even M$ would be so effing thick as to pull a trick like that, but in truth it wouldn't surprise me.
              They probably didn't consider Yeti's as users.
                the hair on my fingers gets trapped in the keys
                  im suprised the keys stay where they are due to the wind in yer arse.most people have a qwerty keyboard.you have a farty keyboard.
                  www.overfab.uk
                    I believe most are backwards compatible.
                    Obviously some of the actual programs themselves dont work.
                    I had a graphics card driver failure on the new pc when running the guitar software because it was old an outdated... apparently! The new software fixed the bugs on that.
                    I've got to be honest, Vista isn't bad! The compatibility can be a nightmare but purly programs. Autocad for some reason wont work on Vista properly as of yet.
                    But any files made in say office will work in office on vista.
                    Its nice having a powerful pc again!
                      They are re-enforced with yeti hair
                      off out for a curry soon ..............Pebbledashing will comence later
                        yes it does.
                        Trust your Hound.
                          Originally posted by Taliesins View Post
                          yes it does.
                          Cheers. T'would appear the problem is user related then.
                            I heard that the keys were gummed up with Yeti toenail hairs
                            Trev
                              Trev
                              Toenail hairs?
