DIY injector overhaul
  • DIY injector overhaul
    Been looking on a few sites about diesel injectors and they seem to indicate that they can be diy refurbished, there is not a lot in the injector and if they are put back together in the same way they were taken to bits with all the shims in place and torqued up correctly, what is the problem, i know it would be hard to pressure test them at home, so this part would be out of the question but would they be worth a clean internally.
    I also realize that cleaning is only one problem with them, warn seats, damaged nozzles to name a few, but cleaning could be eliminated. might work ?
    I must point out at this stage that i have a spare set of injectors sitting waiting
    Have a look here and see what you think: http://www.mercedessource.com/node/4802
    Roy
    When ya stop having fun, Ya start getting old
    Price and time wise it'd prob work out cheaper to simply renew them.
    But if you have plenty of time on your hands, why not.
      Price for new injectors is around £800 +vat
      Roy
        If you have a spare set then why not have a play about with it, as long as you have a backup plan then your ok "i think". Someone a bit more tech minded will be here soon im sure.
          Diesel Bobs refurbish them for about £40 each
            Well i didn't mean brand new rodney! Recons are cheap enough.
              But i have a ducks bum and if it can be done then why not have a got, what have i to loose?
              Roy
                Umm, 4 injectors?
                  Where the hell did you get that price from??????
                  They're usually around 70 quid each brand new!
                    Toyota
                    Roy
                      Prob main dealer prices.
                        http://cgi.ebay.co.uk/hilux-surf-bre...1%7C240%3A1318
                        Or if you're prepared to wait a while.......
                        http://cgi.ebay.co.uk/Toyota-Hilux-S...3286.m63.l1177
                          33 quid each to have Diesel Bob work his magic:
                          http://www.dieselbob.co.uk/orderinjectors_toyota.asp
                          If I were you, I'd be tempted to have a crack at them anyway. Bob would probably still take them in exchange once it all goes to hell.
                            Hm
                            I was actually thinking ebay
                            Roy
                              All that is good and posably for the future but current economic climate dictates that spending has to be cut to, next to 0 on the surf.
                              Roy
