Been looking on a few sites about diesel injectors and they seem to indicate that they can be diy refurbished, there is not a lot in the injector and if they are put back together in the same way they were taken to bits with all the shims in place and torqued up correctly, what is the problem, i know it would be hard to pressure test them at home, so this part would be out of the question but would they be worth a clean internally.
I also realize that cleaning is only one problem with them, warn seats, damaged nozzles to name a few, but cleaning could be eliminated. might work ?
I must point out at this stage that i have a spare set of injectors sitting waiting
Have a look here and see what you think: http://www.mercedessource.com/node/4802
and if it can be done then why not have a got, what have i to loose?
