you say they are +2 so why do they look exactly the same size as your old units.?????
Desert Fox shocks!!
Well that's wot Barry says they are, i'm just quoteing, he replaced the +2" procomps i originally ordered with these so what can i sayOriginally posted by surfenstein View Postyou say they are +2 so why do they look exactly the same size as your old units.?????
OK one side done, a few pics, the shock went in no probs, i did give it a coat of clear laquer first to seal the sticker on and keep it looking ok, spacer fitted ok and the manual hub, tyres do stick out a tad further than the 31's so i might have to stick some rubber extensions on to keep the jondarmes happy,
i need to find a couple of blanking grommets to cover to top wishbone grease points, stop those bits filling up with shoit, regreased it before sticking the wheel on,
t'other side was a right sod to strip, every friggin nut and bolt was stuck solid, split a 22m socket on the shock bottom mount, all stripped ready tho,
next step is angle-grind the top wishbone for the spacer and refit after a clean up, feels bl00dy high standing next to it, i can see the old woman devorceing me! should have done the 4" body lift
Last edited by POPEYE; 4 December 2008, 18:23.Too young to die and too old to give a toss
Looking good mate!
BUT... dont put on the plastic on the wheel arches untill someone pulls you over and complains about it mate.
They look cr*p and tacky as feck!!
The tyres stick out a nice amount. Probably less then Stormforces truck but more then mine!
Yeah! i dont really want to stick bits on the arches, i aggree, looks a bit naff, i know last mot the bloke had a good look through his rule book for summat about sticking out tyres, but could'nt find owt, thinks the cops are pretty much ok unless you really take the pi$$,
i had enough shoit spray'd up the sides with the old tyres on Sancho so these are really going to shower it, ya get the cathrin wheel effect
kept em virgin white Andy, if i pay money for stuff i want people to see it
