how big of a lift do i need to have to fit a set of 35x12.5s under my surf?
35" tyres
Depends on use mate.
Ive got +2" coils and 2" coil spacers aswell as1.5" ball joint spacers and wound torsion bars.
On top of that is a 1.5" body lift.
I had to beat the arches out an on the left i get a tiny bit of rubbing on full lock an the right rubs more because i didnt beat enough out.
But it wont flex for sh!t.
a 35" tyre is just too big to go into a surf arch without major trimming.
It looks bl**dy awesome!!!
6" lift is recommended for 35's but you'll never get the flex.
Thats assuming its all 35x12.50's
If you got a set wider tyres then its taller still. 7"+
thats 5.5 inches, I only have 5"私のホバークラフト は鰻が一杯です。
The front lift is only 5" an the rear is 5.5"Originally posted by blackpoolsparks View Postthats 5.5 inches, I only have 5"
But its the 5" thats the most important. If you only fit ball joint spacers or tweak the torsion bars an fit a 2" body lift then your looking at 3.5-4" lift max.
you'll need the ball joint spacers and the torsion bars wound to make it work good on the street..
they will never work great off road without modification to the arches because they just dont really fit in them.
