tyre size
    thanks stormforce
    is it just a case of pooring straight into tank or does it need to be pre mixed do i need a fuel heater
    what does it run like
    like you said my main reasons where the high fuel costs but as there coming down may leave it for a bit at least until they start raping us again on fuel
    know anything about the rear dimister
    cheers jon
      Originally posted by BAV1 View Post
      thanks stormforce
      cheers jon
      Just pour it in to the tank.I don't have a fuel heater or anything and if i do a long run then i just fill the tank right up on it
      Mine runs fine on it but all trucks are different so just start with say 15l and build it up till the truck runs rough and then knock the % back a bit
      Have you checked the conectors inside the tailgate as they may of rusted through
        yeah both the element and switch are ok according to the meter any ideas on where the relay is
        cheers jon
          hi all tyres on the way thanks for help and opinions one last question
          what tyre pressure
          thanks in advance
