Is this an aftermarket mod or are they all adjustable?
Panhard Rod
Tough one to answer really
Lots of mods take place with these vehicles, I feel for whoever buys mine should I ever sell it - it would be like a treasure chest!!
Sus, body lifts usually need an adjustable rod due to the changes to the geometry at the rear end...so quite likely it was done at the same time.
Is yours blue with a floppy white hat??Too old to care, young enough to remember
I would think if the suspension is raised the fixed length panhard would pull the body & rear axle out of alignment.I'm not a complete idiot.......
My kneecap was removed in 1981
Correct. The higher the rear suspension is raised, the more the body shifts over towards the passenger side.
So and adjustable rod is required to lengthen it or a bracket to lower the rod to keep it as level as possible.
If i was to modify the one i have, i would have to cut a left and right handed thread on the bar and on the sleave ? that way it could be adjusted on the truck ? i think the bar is 20mm so i have one tap and die, i may be able to do the small half on the lathe, HmmmRoy
When ya stop having fun, Ya start getting old
I'm quite into my machining at the moment, I've made the body lift blocks, rad dorp brackets and bumper drop brackets, going to make the front diff, arb dorp blocks and balljoint spacers next week, then I'm starting on a oil catch can, so in two weeks I'll have note to do.!Roy
Originally posted by roylittle0 View PostI'm quite into my machining at the moment, I've made the body lift blocks, rad dorp brackets and bumper drop brackets, going to make the front diff, arb dorp blocks and balljoint spacers next week, then I'm starting on a oil catch can, so in two weeks I'll have note to do.!
IanI'm not a complete idiot.......
