Originally posted by bboy02
View Post
Is this a stupid question??
Originally posted by Apache View PostI wouldn't bother unless there's a tyre you particularly like that isn't available in metric sizes.
I have 265/75-16 on my offroad wheels and they are between 31 and 31.5 depending on the make.
Its not. In 'tape measure' terms. But they normally come in at 31.6 which is the same as a bfg 265/75/16.
As soon as you start looking at the 'real' dimensions of a tyre rather then whats stuck on the side it does make you wonder.
Originally posted by bboy02 View PostIm just not sure that changing my 265/70/15 tyres for 31's is worth it, only 1.4 inches larger I think. Would like to see any photos people have taken before and after changing standard tyres for 31's, is there a noticeable difference?Roy
When ya stop having fun, Ya start getting old
Originally posted by roylittle0 View PostSo what is the advantage of a 2" body lift, in wheel terms, i'm mainly doing mine to fit the intercooler in and it will look cool too.
To be honest, Your probably better off thinking about it an then either putting in a 2" suspension lift and 33's or keeping it as is.
If your doing a body lift, make sure your shocks/springs are in good condition. The handling is 'sketchy' afterwards if the suspension isn't pretty firm.
now go on roughtrax an order +2" springs for your 33's
Originally posted by bboy02 View PostDid they seem much different to look at??
Originally posted by RodLeach View PostWith a 2" lift you should be able to run 32x11.50 without too many problems. Especially on stock surf rims.
Roy
Originally posted by roylittle0 View PostUnfortunately my shock absorbers are only 6 months old and I've just fitted uprated springs so handling is good at the moment, that means i won't be allowed to go out and buy new ones at the moment, so ill be stuck with the 2" body lift and standard suspension for now.
Originally posted by biosurf View Postgo to the for saole section, sell your uprated springs and shocks and as soon as someone makes you an offer put the money towards some shiney new ones. go on you know you want toman with a plan!!
