yup you need to fill slowly (i use a jug) then start up and top up as req as it heats up, still say you'd be better off makeing some tee's and doing the final filling that way, save all the faffing about parking it uphill faceing mecca
i always check the the level by the bottles method, gravity being what it is and water finding it's own level means that as soon as you take the cap off water thats higher than the cap's gonna flow out, beats me why they designd the pipes higher than the filling point, bit like the guys that claim these trucks were made to go through deep water and shoit! in that cace why's the alternator fitted down low, the first thing to get swamped and set the electrics going haywire,
if your looseing water each time you drive it's got to be going somewhere, i'd tie a plastic bag on the expansion tank vent pipe and see if it collects any,
ant spits of water out the exhaust on start up? c drain the engine oil and see if theres any in it? failing all that it has to be escapeing onto a hot surface and steaming away, as said there will be some evidence of a leak after a while, like white powdery deposit, useually round the thermostat joint,
