Swb??
  • Swb??
    Has any one taken a 2 door 2.4 and shortened it to a swb?
    Also is it possable to fit a 3l in a 2.4 body?
    it is possible to put a 3.0l into a 2.4 body but you'll need the complete wiring loom and everything to do it
      stormforce - i just sent you an email.
      Do you have parts to do this at the moment?
        i replied to your email.i will be getting a 3.0l in with a blown head but supersurf has a 3.0l in with a good engine so have a chat with him if you want about the 3.0l.I do have a short block 2.4 here as i put in the email
          All the ancillaries, ECU, new engine mount positions........
          Easier to buy a 3.0.
            Why two door? Were you planning to shorten it by cutting middle out??
              have a 2 door
              also thought it would be easier to shorten down
                have a 2 door
                Frame is pretty much the same so follow the advice - buy a cheap 3 ltr and bob tail it
                A lot easier than messing with wiring looms etc
                Just lob Stein some money and your truck.....................
                  i like your thinking :-)
                    For the small increase in power its pointless doing a 3.0ltr install.
                    Cost benefit analysis ( ) just screams "WASTE"
                    Plus a 4 door surf could probably be hacked around more. Your dealing with the back end that could lose several inches. You do anything to a 2 door surf and the rear window will be all over the place.
