Whilst i have the head off i thought it would be an idea to completerly remove the egr valve, i have made some blanking plates ready, they are of 5mm thick mild steel painted, so should be fit for the job, is therte any reason why a can't remove it completerly and block off the vac line.????
and is there anything else i should be doing at the same time, now that the head is off and i have the room in the engine bay.
, the condenser on mine is in front of the main rad, so it will cushion the blow if I hit anything, thus protecting the main rad.
