CB radio
    Decent length ariel? It's not something you can choose for appearance or taste.
    27MHz = 11.1m wavelength so quarter wave will be typically 2.75m, which isn't really practical for a vehicle mounted antenna, so you tend to see 1/8th wave ones which are about 1.4m give or take a bit depending on the type of loading - or the amount of waffle the seller is capable of.
      100% right u are.....
      Get an sirio scorpio lol
      they are long as they don'y have a open coil load
      One day at the time I guess..
        Originally posted by Scorpion View Post
        Cheers mate. I have a Midland 38 so it looks like I'm in luck!
        yep 38 is the same chassis as mine so will fit perfectly....
          Hmmmm, 1.4m is roughly 4.5ft in old money eh?
          Would this be a good size to mount on the rear wheel carrier or would you suggest something around the 1m mark?
            Would you believe it? I just went out to the shed to get my CB & it's gone
            I'm not a complete idiot.......
            My kneecap was removed in 1981
              now that aint good....
                time for a drive round the local car boot sales then!!!
                  It wasn't until I started ranting that someone remembers where they moved it to, I now have the radio, the SWR meter & extention speaker, I have quite a few antennae & mounts so all I need now is some coax.
                  The radio is a midland model 77-104, it's 6.5 inches long by 4.5 inches wide & 1.5 inches thick.
                  I found my amp/preamp too but it's bigger than the radio
                  • #24
                    Radio, antenna mount, coax all sorted, just got to decide which antenna to put on, the K40 on the mag mount I don't want so that will be up for swaps, so it's between the firestick, the base loaded whatever it is (can't remember) the double coiled sirio or the centre loaded modulator.
                    I do have another double coiled antenna but it's massive, too big I think for the surf.
                    • #25
                      Not the firestick, mate. It's sooooooooo 70's!
                      • #26
                        Is there any reason no one's suggested a mag mounted antenna?
                        • #27
                          That's what I have. Good enough range for use when you're out with your mates.
                          • #28
                            Yeah. After buying my CB the other day and testing it out i can't see why anyone would want to use one for any other reason.
                            All i heard was 'CB Enthusiasts' talking about the weather and how good a signal they could get. And one middle aged bloke talking about the Pink CD someone gave him for his birthday....
                            • #29
                              You may find some of these people are disabled & chatting on the CB is their only way to chat with friends without having to pay large phone bills, there are several around here.
                              I have magmount bases but as I like to DX I want a quality fixed antenna but as you say for limited use a magmount would be fine.
                              • #30
                                cough
                                http://hiluxsurf.co.uk/forums/showth...t=49902&page=2
