problem no:1345
    Originally posted by RodLeach View Post
    £61...
    You need to stop ordering from Toyota mate!! Im not just saying it but both Stormforce an Supersurf are bl**dy spot on blokes to deal with!!
    Quick an cheap! Can't ask much more then that mate.
    I can't help with pics mate, I need to change my aircon belt. After the lift its a total sh!t to get into the bottom of the engine bay!
    your right its just me
    i only do cash tho no other way around it
    if i want owt it has to be cash
    i could do with working somthing out tho
      Originally posted by drunkmonkeyboy View Post
      I am dyslexic too and agree that a spell checker only works if you have some idea of what it is you wanna spell in the first place!!
      yes you would never know that with out being dylexic
      madding is ent it
        I think your talking about the idler. The small black pulley that has the screw attached to tension it?
        From memory I think there is just 1 bolt to take off and the pulley should come off. Normally you can knock out the bearings and replace them but I haven't done the toyota one.
        Should be easy but you might have difficulty if you have the aircon rad still on
          Firstly dont worry about your spelling George, oxford dictionary english aint required on "ere" many a time the simplist word spelling leaves my brain,
          after the event mate i know but just dumped an air con idler pully and bracket, did ask on here several times tho, as rod said stormy or other breakers is ya best bet, just replace the whole bracket, two bolts if i remember right, not sure how the pully fixes to the bracket, failing that and if you dont use your air-con , rip the whole sodding waste of space off, more room, less drag on the motor, lets face it this country aint tropicle is it
            thanks guys for all your kind words
            and help full hints
            its done now any how mark at toyota got it nice and early for me
            the old one was set solid
            and mi mates fitted it for me
            they work at toyota for a few years
            i just made the tea
            good mates them are
