A busy 2 days
  • A busy 2 days
    Fitted new timing belt, tensioner and idler, new water pump, new belts, new radiator, new harmonic balancer, changed all the water hoses, full engine service, fixed the viscous coupling (70000 cSt oil), changed the top seals on the injector pump, removed all the air con gubbings, removed a load of unused brackets and stuff, changed the front diff oil and removed my wee dead bird.
    All in all a good productive weekend
    Now all I have to do is see if my cooling issues are fixed! Oh, and I've lost my thermostat!
    Well done mate, we will see you next Sat
    Brian
      I hope that wee bird got a proper garden burial.
      Glad you got it all done, means you can come and play.
      Alan
        I wouldn't personally run it without a 'stat. You'll lose the temperature regulation of the coolant system. It'll spike up and down like buggery.
        Are you still running a white/cream fan, btw?
          I'll be there if my cooling system is working!
          Did you get your towing doofers done? If you did, any pics?
            I'll stick a pic on tomorrow, they look eh....proper!
            Alan
              No, I've got a fancy blue one
              Thanks Matt!
                Thanks Matt!
                You're welcome. I think it deserves a pic in the viscous fan thread though..... (I can hear Vince gibbering already.....).
                  It'll be around somewhere, I'll re-fit it ASAP.
                    I'll take pics tomorrow
                      Sweet.
