Tony did you have to pull him out of this as well
Careless
Originally posted by KoiTony did you have to pull him out of this as well
On order for the pit ready for the 12th
Bone stock except for the following:
Engine
Cadillac 472ci big block
10.5:1 compression from Cadillac 425 heads
Lunati camshaft
Edelbrock intake
Propane conversion w/ 30 gal. tanks
2.5" dual exhaust, Dynomax mufflers
Transmission
Cadillac TH400 converted to 4wd
Transgo TH400 Stage 2 shift kit
HD stock stall torque converter
Transfer Cases
OTT Industries NP203 / NP205 dual transfer case
NP203 is backwards
Twin-stick on NP205
Custom E-brake off rear yoke of NP205
Driveshafts
Ford 1-ton / Toyota Landcruiser hybrids
Ford CV on the front shaft, not on the rear
Axles/Steering
Unimog 404 axles with Exaxt disk brake conversion
Exaxt Hi-steer arm, cross-over steering
Exaxt pinion flange conversion kit
2wd Chevy steering box w/ Explorer/ProComp Ford drop pitman arm
Wheels/Tires
Military issue Hummer runflat/beadlock rims (unmodified)
44x18.5r16.5 Dick Cepek tires
Suspension
Front: BDS 4 inch lift leaf springs w/ shackle reversal
Rear: stock Ford F150 leaf springs w/ shackle flip
Rancho RS9012 shocks
Exaxt shock mounts, torque arm mounts, torque arms
Body/Frame
1987 front clip
3 inch body lift
Mobi-weld welder
Onboard air
Warn 8274 winch
Custom bumpers, extra crossmembers
Rock lights
Dual Optima batteries
Off-Road Design weld-in and bolt-on steering re-enforcement kits
Bushwacker cut-out flares
Interior
JVC/Pioneer CD stereo system
CB radio
Ford Aerostar bucket seats
Smittybilt Interior cage (for driver & passenger)
Dimensions (aired up)
Wheelbase: 108 inches
Height: 95 inches
Width: 88 inches
Step into cab: 42 inches
Clearance at diff: 19 inches
Clearance at t-case: 26 inchesSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
