Originally posted by GIRDLES
View Post
Filtering veggie again
Originally posted by GIRDLES View PostI believe the 27/3 test is to check for fall out on processed oil ie Biodiesel. The bio 3 PARTS is mixed with methanol 27 PARTS and shaken to mix then settled,all the unprocessed oil and soaps will fall out showing an incomplete reaction.
The process of washing Biodiesel is to remove Methanol, so by adding methanol to a tank of WVO I cannot see the point.
to alter its cetane rating.the acidity of well used wvo nearly plumbs off the scale. it depends on its animal fat content and therefore its amino acid content.a few months on fatty wvo will almost certainly kill something vital in your injection system. the addition of an oxidant will alter the atomic structure and its molecular count.
Filtering after settling is all thats req, Thin with some Diesel when it gets cold. Using Veg oil as fuel not making it into Biodiesel.
I have had no problems running 80-100% all summer using the method above.Enjoy your cheap motoring.
which many do. well thats mainly detergent and a kerosene deriviative,
and is also known as an "improver"
it makes diesel (28 point combustion) into a fuel slightly more flammable, with an (approx) 25 point combustion point, which has a flash ignition point closer to the 105c required for max efficency
if you add this oxidant you WILL improve combustibility, you WILL settle out more shoite initially, you WILL keep any vital fuel components cleaner....it works on an industrial scale,on applications from fuel crackers to waste water/oil sep plants.
just filter and settle apache and bdt2 and if its really fulthy chuck something spirited in it................am i repeating myself....Non intercooled nothing.
i should point out there are more than 30 different, patented ways, to process crude into various products.depending on the stage its refined at, you can
crack it
cook it
transtesterfy it
catalyse it
and so forth and so on.the point is there are many "snake oil" ways to process your wvo.
what the vendors of various bits of processing kits probably dont want you to know, is that the simplest system (filter, settle) is probably 99% as efficent as the most complex £ 5000 home kit you can buy.
and adding acetone is bow locksNon intercooled nothing.
Originally posted by gwh200 View Posti should point out there are more than 30 different, patented ways, to process crude into various products.depending on the stage its refined at, you can
crack it
cook it
transtesterfy it
catalyse it
and adding acetone is bow locksam not die lex sick its you that cant read mate
Originally posted by JUDWAK View Postredex acetone? do people realy beleve that load of twiddle?
redex, or other detergent based improvers, especially used with straight veg oil is pretty good george.
acetone is pretty useful for dissolving oil based paints (ie the wife rubbing off her nail polish) and..errr that about it for acetoneNon intercooled nothing.
Originally posted by gwh200 View Postredex, or other detergent based improvers, especially used with straight veg oil is pretty good george.
when raw that is
but from what i read about animal fats non of the above is any useam not die lex sick its you that cant read mate
Originally posted by breakdowntruck2 View Postmy prob is the oil im gettin is shite,almost lard in the cold now lol
