Inline temperature sender
  • Inline temperature sender
    Anyone seen any oil temp senders that connect inline in 3/8" hose? I want to monitor temp of ATF coming out of the auxilliary cooler.
    Re
    I think I saw them in a shop on ebay mate.
    They come in all sorts of sizes and materials.
    Do a search and see what comes up!
    Gary
    EDIT
    HERE
    HERE
    HERE
      http://www.triumphshop.co.uk/Quiller...ies/guages.htm
      I found these but they ain't cheap. I am looking for the same type of gauge fitting!!
        Sadly all to big. Needs to fit 3/8" ID hose. Think I'll have a bash at making something.
          Have a look on here......
          http://www.cbsonline.co.uk/
          I can't be arsed.
            Made mine from some brass stock,
              Nev made an inline coolant sensor adaptor from brass connectors, I believe. A slight variation of that would probably do the job. Seem to remember it was all off the shelf stuff that was used.
                A 3/8 BSP Tee, two 3/8 BSP hose tails to suit trans hose and a 3/8 plug drilled and tapped to 1/8NPT will do the job. Here's the inline turbo hose adapter.
                  If drilling and taping with NPT do not run the tap do deep. Thread a small amount and then check how far the sender screws in. They are a tapered tap and if you run the tap the full depth then it will be way oversize for the sender.
                    What an excellent idea!
                    I haven't checked my sender yet, but I have a feeling its a metric thread (M8 I think) - which is better for me as I have a set of metric taps.
                    I suppose I'll be wandering around the plumbing aisles of B&Q this weekend then...
                      Yo, sticker bloke!
                      I gonna be ordering one of these kits...
                      http://store.summitracing.com/partde...5&autoview=sku
                      any use for your tinkerings re: this thread?
                        Flippin 'eck Vince. Talk about doing it the easy way!
                        I have just ordered some 3/8" barbed hose connectors threaded 3/8" BSP on the other end, an 1/8" NPT tap, and some brass bar to make the fitting out of. Just considering buying a 4 jaw independent chuck for the lathe too, so I can make it from square bar - which is more elegant...
                        Total cost (excluding the chuck!) - about a tenner. Satisfaction in doing it myself - priceless
                          Hexagonal bar would be nicer.
