got the cabling run through from the winch motor to the solenoid,got the solenoid box mounted.................and its pi55ing down,going to finish it later
well i went outside again,and it rained...again, so i ran the cabling to the bulkhead,where im going to put the solenoid box(having the remote inside so i can winch inside if needs be),just have to get all the connectors sleeved and insulated and perhaps an hours work......hope it works !!
yeah thanks mate !! .seriously,before i do any more installation,i want to sleeve all the terminals,and the cabling is DAMM tight where its threaded up to the solenoid, so i want to sleeve it where it may rub
i managed tonite, to cut away a bit of the front valance,mount securely,the solenoid to the bulk head,and start to sleeve the main control cables ,where they might rub......its turning into a bit of a work up !!
the big wire up will have to wait till thursday as am busy till then,hopefully pics will be apparent
