Help Urgently Needed
Had the same probs mate. ATF cooler is without doubt a good idea if towing. Just fitted a Roughtrax rad a couple of months ago after a few leaks appeared in the top od the old rad, and have had no overheating problems when towing since. Also lifted the back edge of the bonnet with aid of a few washers as packing to help the heat escape from the engine bay.
Spoggle
I'm here - you don't need to be local, there'll be no trouble here - I'd have the RoughTrax one any day - Milner's rads have had some bad press.....Originally posted by Baldy 69 View PostThanks for the advice and guidance guys;
Think I will let the mechanic look at it Thursday, with the history of the previous leak, it will prob be a new radiator.
Just checked Milners & Roughtraxs sites, Any ideas why Milners are £100+ cheaper than Roughtraxs for a new rad, is one and genuine and one not?
Anyone heard from Mudsurfer recently? wondered if he could help with his local knowledge.
Thanks,
mark.Too old to care, young enough to remember
Thanks for the response Mudsurfer: Thought you had dissappeared!!!Originally posted by MudSurfer View PostI'm here - you don't need to be local, there'll be no trouble here - I'd have the RoughTrax one any day - Milner's rads have had some bad press.....
Problem being I can't afford the Roughtrax Rad at the moment I am on a really tight budget at the moment, still trying to catch up with my finances etc after my illness, I was wondering if there was anywhere local that could re-condition or repair the existing Rad, thought that might be a cheaper option than purchasing an inferior product, have since found another company on the net that have 1 in stock for £120 inc a 12 month guarantee.
Think I will wait for for the diagnosis from the garage tomorrow and see what needs doing, Do you know anyone local that will repair or re-condition a rad?
Mark.Entered this world with nothing, ain't got much of it left.
If it needs recoring, (which it most likely may after your radweld trick, unless you're lucky), you won't save much over getting one new. You've done a stupid trick once by trying to save a few bob, so don't make the same mistake again. There is a very good reason why it's called experience, you know.
Originally posted by MattF View PostIf it needs recoring, (which it most likely may after your radweld trick, unless you're lucky), you won't save much over getting one new. You've done a stupid trick once by trying to save a few bob, so don't make the same mistake again. There is a very good reason why it's called experience, you know.
so says the pasty faced soothsayer
Non intercooled nothing.
Sounds O.K.................Roughtrax are tried and tested, It's a case of ya pays ya money, ya takes ya chance. Any one got any feedback on the Manchester outfit?Originally posted by Baldy 69 View PostJust received another quote from a company in Manchester, Heavy duty rad, ideal for towing, £160 inc Vat & delivery; 12 month no quibble guarantee.
Sounds too good to be true?
Spoggle
