SURF side sticker
  • SURF side sticker
    how easy is it to remove the great big sticker on the side of the surfs? i think they look better without them.
    has anyone done this, and will it damage or leave marks on the paint / laquer underneath?
    Oh Nana, what's my name?
    The answer will be a Caramel wheel
      cheers..
        It's a total pain in the arse by the way.
            Never done it myself, but have experience of other sticker removal.
            Personally, I would try heat with a hairdryer (do you know a 3rd gen owner?) and peel a corner, then spray a proprietry sticker adhesive remover into the exposed area and continue to slowly peel / spray as you go. There *should* be less after effects (ie less clean up time!) using this method.
              I'll second the caramel wheel, as that was the method I used. Took one shift at work to do it, followed by a good T cut and polish and she looked much better.
              Gone from 4x4 to 1x2
                nothing is ever easy, and usually things like this, you will end up wishing you had left well alone in the first place
                  thanks fellas.
                    Bored in lunch break so just found this which may help and gives a link to buying what you need. http://www.uksignboards.com/viewtopic.php?p=129599
                    also makes you thanks your lucky stars that we have avatars and not photos of ourselves on here. SCAAAARRRYYYYY!!!
                      omg! looks like a bunch of police mugshots!
                      who's the bloke in the dark with the cheesey grin and strange look in his eyes? it feel like he wants to touch me in a secret place
                      cheers for the link btw
                        just done my truck, took a while ,but it was worth it. i used a heat gun ,some t-cut and some adhesive remover. there are a few bits of glue residue left , but nothing bad.
                        have fun, and lots of patience, alcohol helps( for drinking)
