dog owners...........
    this is what i use and comes with cable which is wire inside
    down bottom of page
    http://www.petsathome.com/find/categ...avel/psi-is-24
      http://cgi.ebay.co.uk/xl-dog-anker-s...d=p3286.c0.m14
      here's one with a cable
        DA SLUG MAN
        that ones not bad as mines L shaped now as dog bent it over and mines not
        a massive dog just staff X english bull
          seen em in b&q for something, can't remember what though. We only used ours a few times, if the ground was soft enough to put it in our elkhound could pull it out, i don't think our alsation would even notice it was in the ground tbh.
          You could probably just bang a length of angle iron into the ground, might hold better anyway, but it'd certainly be ok for a jack russel, drill a hole near the end to put a small shackle through for his lead.
          =SOLD UP!=
            I took the metal lead off our corkscrew thing and just loop it round the van chassis when we're away.
            No ground anchor of any description will hold our dog back when a squirrel runs past his nose
            Chris
            Signature stolen along with Surf...
              Chris
              The Dad of the Jack Russell I have now, dug the corkscrew out of the ground whilst left alone for a bit. Tenacious little bugger he was....
              If you play with fire.....
                And here he is, looking for rabbits a la Meerkat!
                http://i297.photobucket.com/albums/m...wack3r/019.jpg
                  cheers for help guys,just had a thought with all the talk of them being pulled out,may got look for light chain,and put it round caravan axle,as she will be in the awning anyway
                  • #24
                    Oh come on...what you do for a living....spring off a small motor, heat up one end bend it out and put a point on it, weld other end to itself, small shackle + welded light chain, wind that into the ground ...jobs a good'un...minimal cost!!
                    Tony
                    • #25
                      i can see wot your saying,and we do have alot of scrap,BUT my boss is so tight he wouldnt let me have a spring lolol
