Anyone got any trick ideas for getting the front lower shock absorber bolt out? Mine has siezed solid to the sleeve in the bush. Hitting the bolt only bends the mountings.
Front Shock Absorber Mounting
I used a large pin punch to knock the bolt through. Try it with the weight of the truck on it's wheels.Originally posted by Albannach View PostAnyone got any trick ideas for getting the front lower shock absorber bolt out? Mine has siezed solid to the sleeve in the bush. Hitting the bolt only bends the mountings.
oohhhh......tough break!Originally posted by Albannach View PostAnyone got any trick ideas for getting the front lower shock absorber bolt out? Mine has siezed solid to the sleeve in the bush. Hitting the bolt only bends the mountings.
I've had to saw down either side of the bush in the past. Its not pretty.4x4toys.co.uk - Keeping you on and off the road...
We had a quick bash at the penetrating oil, but I think it's past that stage. Didn't do the heat thing as that's not recoverable and I didn't want to be carless this weekend. Cutting the thing to bits is the next plan, it looks tight though. Will an angle grinder get it?
I don't think the punch will do, the rear part of the mounting is bending when hit.
Wondering if there's enough room to get a puller/press in to press it out?Last edited by Albannach; 2 July 2008, 20:18.Do you know that, with a 50 character limit, it's
