try bleeding the clutch slave cylinder its quite possible that you have air in the system and its not fully depressing the lever.(does the clutch feel like its slipping,loss of power.does it make a noise when you depress the clutch pedal..)oil level plug on g/box,undo and you should be able to put your finger in there to check the oil level. the oil should be level or just below the plug.
