where not to leave a soldering iron
  • where not to leave a soldering iron
    Was doing a spot of soldering tonight and rested the soldering iron on my leisure battery. Didn't realise the hot metal end was touching the battery, until I started to smell burning plastic
    I humbly throw myself at the mercy of an idiot tribunal.
    P.S Slug Man I'll still swap you the picture of Hunter if you want
    Hold my beer and watch this
    if you like, i'll put a soldering iron to his face??
      All too easily done. One thing I might suggets is just popping some epoxy resin on that melted point though, just incase it's gone through a ways. Should prevent owt escaping.
        it went all the way through, can it be plugged still?
          Yeah. Araldite or suchlike should work fine. Make a bit up and pop it into the hole as the initial plug, below the level of the outer battery face. Then, when that has started setting and got to the tacky stage, make some more up and put a good second layer over, extending past the melt edges. Epoxy is resilient to acids, if I remember correctly.
          The way that a soldering iron usually melts plastic gives it a good rough keyed surface, so it should bond quite well.
            thanks, will have a go at reapairing tomorrow
              You sound like you have lots of experience of this Matt. Not heard of an iron stand then?
                Ones modelling skills to repair customer damage have included the art of 'soldering iron modelling' in the past. Plus, one or two engineers I've worked with in the past had a novel method of removing the plastic strengtheners from chassis if they were in the way of a repair.
                  The word PILLOCK come to mind .............
                  Thats coming from someone who set his hair on fire when using a gas soldering iron
                    CARELESS for you jessie very Careless does trev still put people up for the vote for this?
                    nice to know the Master is just like us
                    Enjoying Life after Cancer
                    Pops
                      Originally posted by pops View Post
                      CARELESS for you jessie very Careless[.........]
                      Ones mind works far too fast for the fingers to keep up with on occasion.
                      (I'm sticking to that excuse).
