I'm coming down Sat and leaving Sun but if I get the chance I'll pull-in.
The Bundubasher...
Originally posted by bundubasher View PostJoker - pls report on the quality of the filters when you get them. Is yours the 3.0TD?
all the filters are boshi
been getting them from sdn ,roughtrax etc all the same except the price
milners is the cheapest
kzn185 , only the air filter is different
I see you've got the 3.0TD - and you say all filters etc are fine? OK I'll order a couple of sets.
Otherwise, I've received the wrong parts from Milners in the past and friends on the ELCO website (with 80 series cruisers) have had big problems with Milners bearings (and CVs I think). These are parts that take a beating and so I always try to buy the best that I can afford.
Where's BushBuster based?@africa4x4cafe
[url]www.africa4x4cafe.com[/url]
I believe, (if what I've heard is correct), that the only general thing they lack is the drainback valve, i.e: the one that holds some oil in the filter on engine shutdown.Originally posted by Apache View PostEnzo, I've had milners filters several times now. They seem just fine. No better or worse than any others I've used.
To be honest, where the oil filter is concerned, the genuine Toyota one is the one I would recommend if spending a few quid more ain't a problem. The 30002 does, by all accounts, also have a second bypass element.
Edit: This is a list of filters which should be compatible:
http://outgoing.bauchan.org/toyota_s...fo/filters.txt
They probably are over here too.Originally posted by bundubasher View PostIf it was a few quid more then I wouldn't have a problem but in EA a genuine Toy filter is about 4 times the price of a Boshi.
They are about £15 quid from the dealer. Oil filters are the one area especially where I personally believe economy types ought to be avoided.
