Top Rad Hose
  • Top Rad Hose
    everything seems alright,running fine heater needle staying on half, bottom of rad quite warm when i took her down motorway.got home checked 4 leaks none exspansion tank half full but top hose hot and solid any idears anyone
    NEVER GIVE UP SHES WORTH IT*
    Did you change the stat and the rad cap already?
      yes stat changed and new rad cap.
        Flushed the radiator?
          sancho just had head done flushed rad everything seems ok but apart from the top hose getting hot and solid.i dont want to throw the van on the back and tow it and it blows up or something,
            when you say solid is it the pressure in the system? The pressure it runs at can be quite high it will tell you on your rad cap.
            Trust your Hound.
              ha the proplem is its just silver if it had something on it which it did when it went into the garage its not now,any other way of finding out.
                Was the water pump replaced when the head was done?
                  Is the bottom hose'solid' too? when up to operating temp and pressure hoses will feel 'solid'
                  Trust your Hound.
                    Solid top hose is fine it is supposed to be as the rad cap is doing its job .Pressure in the system upto rad cap setting lowers the boiling point of the coolant. Its when it pushes out into expansion bottle you got problems .
                      Will you use proper English instead of that b@stardised shorthand and word dropping. It took several reads of that paragraph to understand it correctly.
                      Top hose should get quite firm in normal use. Did it pull the excess back from the expansion tank as it cooled? Was the coolant level okay under the cap once the engine had cooled down? If the system was over pressurising, it would most likely have popped a leak somewhere, so I wouldn't worry too much, personally, provided everything appeared okay as mentioned above.
                      Btw, if the rad cap has no markings or anything on it, replace it as a precaution.
                        When the expansion bottle overflows, to be precise. T'was a tad misleadingly phrased, Rick.
                          I stand or sit corrected Sir . I tip me hat to you guv .
                            cheers everyone sorry its took so long to get back,took her out for a run,up and down m60.got back just checked everything exspansion tank half full same as when i left,no leaks anywere,needle on temp staying just under half way,so hopefully nothing to worry about,checked all advise given.getting new rad cap tommorow,it must just pressure up that way cheers everyone.
                              matt try a bit of texting on your mobile thats if u can use one and you will under stand haha grumpy old fart ps joking.
