Just after some additional advice regarding water removal from WVO, if anyone has any ideas or suggestions. ![Smilie](https://hiluxsurf.co.uk/core/images/smilies/smile.png)
Several possibilites at the moment, and just wondering which might be the best way to progress.
1) Chuck all the oil into a 55 gallon steel drum, (rough filtering it on the way in), and then heat the oil in that container to attempt to shift any water and then just let it settle for a few days, then run it through a fuel filter for the final filtering.
2) Plastic 120 litre drum. Pop the oil into there, (again rough filtering on the way in), and just leave the oil in there for upto a week or two for any solids and/or water to settle via gravity, then tap off from about a fifth of the way up the drum through a fuel filter for the final filtering. Thought one of those water butts with the tap near the bottom might be useful for this option. Possibly add another outlet slightly further up than the tap, and use that to pull the oil from, and then just use the tap to drain out the dregs/water.
Opinions or suggestions?
p.s: Yes, I know i'm an over complicating finnicky fart.
![biggrin](https://hiluxsurf.co.uk/core/images/smilies/grin.gif)
