does anyone know wether the v6 front drive shafts are the same as the 2.4,i.e spline wise,sounds like i have a bronze bush problem with the v6 and bio has a complete front hub with new bushes and bearings just wondered if it will all swop over ok.dont want to start stripping it down to find it wont fit.cheers in advance.
can anyone help
same part no on the EPC mate, so should be good
for reference:
43430-35011 / 8906-9606 / SHAFT ASSY, FRONT DRIVE RH / KZN130,LN107,108,109,112,13#,V ZN130,YN107,130
Part Number / Production Date / Part Name / Models (Description)
(SUBS) 43430-35012 = substitute part number, normally means the original part has been superceded by this one, either because of a fault or a change in design, toyota may well no longer be able to get the original part, and you'll have to use the substitute part number to order it by.
- same one for the LH side too!=========
=SOLD UP!=
Anything from 4/89 to 8/97 should be the same for the drive shafts and steering knuckle. There was a change in outer CV to steering knuckle seals at some stage and if these need to be changed then you have to get both (expensive) seals for the shaft and steering knuckle. Check the seals and make sure they match. The 1/90 seems to be when the seals were changed. If both vehicles were manufactured after this they should be the same.
Originally posted by BioHazzard View PostPlease what kind of person do you think i am .................can i get some overalls on firstwww.overfab.uk
Originally posted by surfenstein View Postwell i know one thing,it gets worse when you turn a left hand corner,and if you grab the drive shaft you can rattle it around in the hub,its making a horendous noise.you working all week????' You've arrived on a rather special night. It's one of the master's affairs.'
Originally posted by surfenstein View Postso what do you reckon on me coming up early one morning this week to swap em over????
where yer avatar gone????' You've arrived on a rather special night. It's one of the master's affairs.'
Originally posted by UDTrev View Post
His star's gone walkies too !!!!
Or has he not paid his subs ?
i think it runs out soon thoughLast edited by BioHazard; 10 June 2008, 08:50.' You've arrived on a rather special night. It's one of the master's affairs.'
