Originally posted by BioHazzard
View Post
can anyone help
Originally posted by nero279 View Postsame part no on the EPC mate, so should be good
for reference:
43430-35011 / 8906-9606 / SHAFT ASSY, FRONT DRIVE RH / KZN130,LN107,108,109,112,13#,V ZN130,YN107,130
Part Number / Production Date / Part Name / Models (Description)
(SUBS) 43430-35012 = substitute part number, normally means the original part has been superceded by this one, either because of a fault or a change in design, toyota may well no longer be able to get the original part, and you'll have to use the substitute part number to order it by.
- same one for the LH side too!
Hi all,
I disable my noisy SHAFT ASSY yesterday and discovered the big bearing inside of it is broken. (the one close to the wheel)
Does anyone of you know the reference of the bearing itself to order it? (or at least exact name) because I just find the complete SHAFT ASSY RH...
Thank you
