overheating
  • overheating
    ok the story so far
    me truck is overheating 3,0Ltr. not a 2.4
    the water is bubbling back into the expansion tank.
    the rad and engine were flushed back end last year
    plan to remove rad this weekend to flush the rad fins out as truck does go off road whenever possible so could be that
    got a new stat at ready too (does this fit were top hose goes to block )
    any thing i missing guys???
    boils up just driving to work now 24 miles
    Enjoying Life after Cancer
    Pops
    Originally posted by pops View Post
    ok the story so far
    The Thermostat fits where bottom hose (metal housing) goes into the block.
    Trust your Hound.
      Pops,
      Is it any noisier ?
      Has the oil pressure dropped any ?
      WHATEVER happens get that rad cleaned sharpish
      Trev
        Originally posted by UDTrev View Post
        Pops,
        Is it any noisier ?
        Trev
        NA the head ok no water in oil
        got stat to wack in and rad out at weekend as i said
        ###### nuisance tho as no way to get to work if she gives up
        Pops
          mines been doing the same (2.4) tho
          i found that every few days i have to put in about 3 ltrs of water
          or she will over heat
          so i watch her closely when she is at running temp she is fine
          untill i give it some
          up hill or something it starts makeing the temp fluctate
          and no its not the head i have checked every time i over heat
          water is bubbling out of the breather pipe slowly but over time it makes my water level go down to a point that i over heat
          so now i drive around with lots of water in the boot
          and the heaters are allways on
          the heaters dont carry the heat properly when the waters low lets me know before it happends
          and my 2.4 has done nearly 100.000 km with its factory fitted head
            Just cause theres no water in the oil does'nt mean the heads not cracked 3.0 crack as well.
              did you get the dell job marky ??
              Non intercooled nothing.
                Oi this is not the job centre its a thread for an answer to a diagnostic problem
                so please do not take over my thread
                NOW did you get the job Marky so i can get back to my thread
                Pops
                  terribly sorry old chap,wont happen again.it sounds like either the thermostat is in need of relacing,or the head is on its way out.you dont need to see any oil in the water to confirm a cracked head,but you may need to get it tested for exhaust gases in the coolant ,halfords were selling the test kit for about 15 quid..........and c,mon marky did you get the job ??
                    I went for 2nd Interview just waiting for a Decision. I also Met Johnny toyota,
                    Nice chap gave me the TOYOTA EPC DISKS.
                      dont ya mean water in the oil lol
                        well yes ,both mate.
                        but get the coolant tested for exhaust gases as well pops
                          dont think the heads gone i think its the rad myself
                          marky good luck son now move on nothing to see here this is my serious thread
                          thanks for all the advise guys will check it out on saturday and report back
                          Pops
                            when are you up north mate
                              def leppard in manchester on 20th mate
                              Pops
