I think the oil leak on this new truck is coming from inside the gearbox as there is only a small amount of oil at the top end of the bell housing and the rest is totally lagged and only leaks when the engine is running.
Is there any where else the oil could be coming from.I cant see any oil coming from around the head anywhere or the rocker cover so it seems like the gear box/bell housing area.
If it is this seal insidethe bell housing i know the gear box has to come off but how hard is it to do the seal as i may end up having to do that.
I have also got to get the tickover raised a bit as its at about 600rpm.
