Does anyone know how much of a job it is to refit a standard steering wheel and air bag to a 3rd Gen ssrx ? Mine had a sports wheel fitted by the original owner in Japan.
Steering wheel problem
Its not a big job. Undo 6 allen key bolts an then one big one to remove the hub an then bolt the other wheel back on in place of the hub..
Airbags.. Now im not sure how hard/easy it is to sort that. Should be a case of just plugging it back in.
One thing is to check if it has an airbag warning light. If its removed that triggers an then it wont pass an MOT with it lit so out comes the dash to sort it. You'll need to working an visible to make sure the airbag is set an ready when it goes back in!!
Not a big job at all really... just sounds scary!
before you play with the air bag system disconect the batteries, be aware that the system will still activate once the batts are disconnected i think you have to leave it for about 3 or 4 mins before working on the srs system. I think anything in yellow connectors is a safety system. I am probably talking complete shite if so ignore me, may be somone else might correct me if i am wrongSWIFT AND BOLD
its 30/40 minsOriginally posted by charvell View Postbefore you play with the air bag system disconect the batteries, be aware that the system will still activate once the batts are disconnected i think you have to leave it for about 3 or 4 mins before working on the srs system. I think anything in yellow connectors is a safety system. I am probably talking complete shite if so ignore me, may be somone else might correct me if i am wrong
