Members truck on ebay
Just theorising, but...
Assuming a Landcruiser 4.2 produces ~25% more exhaust gasses than a Surf, then the impeller will be bigger on the turbo to suit.
Therefore the gasses from a smaller engine will not be sufficient to produce the pressure in the compressor that the larger engine would.
Therefore the performance gains will not be as big as people might think.
However...
A Surf turbo exhaust side, mated to a LC compressor might produce a higher pressure - a hybrid if you like But then the engine management would bet a bit funked about it and put you into limp home.
So, Andy, if you were thinking... personally I wouldn't bother, unless you are going to remap the ECU, modify the new turbo etc etc.Cutting steps in the roof of the world
No no no no no no no no no no no no - NO!
Just thought it was a bit odd - not for the reasons you mentioned, I don't have anywhere near the mechanical mental capacity to have got close to that but, wondered if he meant it was for a Landcruiser (Prado) in which case, it's the same one that all 3.0 Surfs have anyway.....but I like the way you think.....
The only other thing I want to do on my truck now is uprate the alternator at some stage in the next year or so....no turbo changes unless mine gets knackered...Too old to care, young enough to remember
Originally posted by Apache View PostWhat about two alternators?
One for each battery? (Assuming your splitting them)
Switchable incase of emergency?
Or is this getting a bit complex now...
I've heard about using the aircon pump to power another or be another alternator, but I use my air con in this one - not sure how I'd get another one in there TBH...Too old to care, young enough to remember
Dont know about the techinalities (?) but i can vouch for it going like $hit off a shovel, he took me round the estate in it, mine felt like it was going backwards after that, apparantly it was a straight bolt on replacement but other than that i've no idea! wish it'd fit on my 2.4 thoToo young to die and too old to give a toss
Originally posted by Apache View PostBut thats from two 2.4 owners, and Ians is weighed down by the Far East's LED production from 2007!
Lets face it guys, compared to a 2.4, a glacier has 'shit off a shovel' performance!
I'll inhale that remarkToo young to die and too old to give a toss
