Do the side lights have to be turned off, (by law), when the main headlamps are on, or can they be on with the headlamps?
Side lights question
Do you mean side lights or dipped heads? sides can stay on but usually dipped go off when high beam is switched, although i dont think it's illeagle to have dipped and main on together, just bad form to blind some other tw#t thoToo young to die and too old to give a toss
Originally posted by POPEYE View PostDo you mean side lights or dipped heads? sides can stay on but usually dipped go off when high beam is switched, although i dont think it's illeagle to have dipped and main on together, just bad form to blind some other tw#t tho
Hey Ian, I saw an illeagle on springwatch!
Originally posted by MattF View PostCheers.For some reason, I thought the sidelights usually were off when the headlights were on. Obviously not.
Originally posted by BUSHWHACKER View PostThink of them as back-up lights if the headlights fail. If you lose illumination completely from one side of the vehicle, it's an on the spot fine if you're caught.
Here's an idea, switch on headlights, jump out of truck, walk 'round to the front of it and see if the sidelights are on as well!
Pardon?
Whats that you say? You can't reply to this thread because you're banned?? Oh dear.
