Air filter/veg oil
  • Air filter/veg oil
    Time to pickle all your brains, or try too, am trying to make a wee system for wvo, thinking o using an air filter, would this work for passing oil through, would it get down to the right micron size
    I give up. It's now open season
    Matt, Albannach, Sancho feel free
    Brian
      No mate, because particles of the air filter would eventually contaminate the oil (they're paper based you see).
      Why don't you just listen to Yoshies advice?
      You could always put the air filter inside a pillow case I suppose!
        I'm so glad you've finished being protective over him.
          If they were of any use for anything other than filtering air, they wouldn't call them air filters would they. If you really want to carry on with the tight arse attitude towards filtering, the minimum you should be doing is getting hold of something like a second hand Lucas Ford *FUEL* filter that uses the canister type element and filter it through that system. You at least then know it is filtered to acceptable levels for a fuel system. Replacement canisters are cheap, hence the suggestion.
            There's some sheep on the common land near me.
            Can I filter WVO through sheep?
              yes
              Non intercooled nothing.
                Depends. Shorn or not?
                  Cool, I need to make a rack to hold them in place. Scorpion racing make a sheep rack...
                    Hell, get some wellies and ram their hind legs in. Oh, wait, that's different..........
                      Shorn or not?
                      Not 100% shorn, thats why I asked.
                      If I was shorn, I'd be doing it already...
                        Apparantly you can use cows and pigs as well...do scorpion do holding frames for these as well ??
                            No, but Pig Racing do a Scorpion holder. Not sure a Scorpion would get down to less than about 30 microns though...
                              nothing wrong with asking peoples advice, just trying to think o methods to do it thats all, dont ask u dont learn, ha ha
