With the following air fittings?
1, 2 x 1/8th BSPT threaded 6mm OD push fit conn's
2, 8 x 1/4 BSPT " " " " (like the pic)
3, 2 x 8mm -6mm OD reducers,
4 2 x flow regulators (6 or 8mm) and most importantly!
5, five port 12volt solinoid valve,
I've found some fittings supplyes but cant find the valve, all i've seen are mains or 24v, also found some pipeing diags and looking at em i dont think the soiinoid valve set up on this comp i have is going to work so i think i'd be better leaveing that for air bags (at a later date) and doing the ram from scratch,
If you have/can get (but not pinch) any of the above stuff that would be great, obvisiouly pay ya what you want for em, or can point me to a supplyer that dont cost a fortune, i'd be greatfull, (before i put the gun in my mouth
