Got my snorkel fitted
  • Got my snorkel fitted
    Yes that is correct safari snorkel is now fitted and ready will put pics up later of it, didn't do it myself as i didn't want to cut my wing up
    Next up is the landcrusier 3" lift
    :thumbs:
    do yourself a favor, and slap a load of sealant where the plastic pipe along the wing goes into the airbox, its not part of the snorkel kit as its in the toyota pipes that are still used, but there is only a foam seal from the factory, and it could get water in as its not a snug fit.
      nice 1
      is it home made?
      like mine
        Where's the pics then?????????????
          :thumbs:
          wonder if he made a little step bracket ????
            :thumbs:
            Hey Tony u mean when the pipe comes into the engine bay?
            Hope so don't fancy having to take the snorkel off
            It was the safari snorkel i got off tony the other week Judwak
            Bushwhacker had to go to work and was running late so i will take some pic's and use digi cam and get the bull bar shown too, and later i have to sort out the tow bar again.
            Joker what little step bracket, is there something i should have done
              Have a look at the airfilter box, the pipe in that is bolted to the inner wing, just rests in the airfilter box, with a little foam seal to stop it rattling. I like to use sealant round this join to seal it up as the foam obviously isn't airtight.
              The step bracket is something we made on Jokers truck to get this pipe to sit better in its hole, as his didn't line up very well. (probably from a major front end collision in its past............. :ducks and runs away: )
              Its not part of the snorkel, the last bit of the snorkel kit joins the front of this pipe, its like it from the factory.
                i form filled the sump hole in the air box
                just take the filter out fill to sump hole up with formfiller
                it worked for me
                this is me trying it out for the first time its all or nothing
                http://s288.photobucket.com/albums/l...3-08_14011.flv
                  george,you are quite ...mental
                  Non intercooled nothing.
                    it worked for me
                    i loves watching that when the lady says ''ohhhhhhhhhh myy godddddddd'' has me in tears laughing
                      i have no idea who they were that filmed it but it was very nice of them to bluetooth it over to us
                      she was very posh tho and good looking
                        whys that then?
                        its no me thats mad
                        its the rest of the world
                          Tony i took the filter out and i can see the clear silicone around the inside of the pipe you mean, i'll put some more around there to be sure,as for the fitment it looks to be pretty close but will silicone round that too
                            Ok a little update i put silicone around the outside of the pipe and opened up and removed the filter and put loads around the inside of the pipe too, so that should be sorted at last and sealed tighter than a ducks ass
                              heres what tony means
                              [quote tony]probably from a major front end collision in its past............. :ducks and runs away: )
                              thats why i only paid £600 for it
