I've had the joy of owning a UK '96 3.0TD for one year (after 6 years in US with an '86 4runner), and have recently been having much grief with white/blue smoke. Does anyone have any ideas ?
This vehicle has 75K on the clock and compression of 280-/+10 on each cylinder, i just had a new turbo fitted, and still there is some smoke though it got a lot better (and it accelerates much more...). What's really weird is that it seems to be variable and almost intermittent, suggesting that it is not a busted piston ring, or knackered valve guides. It is worse when cold, and seems to be mainly at idle or pulling away, not under deceleration or when accelerating while moving. It looks like the head has been replaced, as well, which is odd for so few miles (previous cracked head or stuck valve??). Also i've had the injectors cleaned/serviced as it was knocking a lot. I'm wondering if it might be the injector pump, or possibly the crankcase ventilation system.
Has anyone else had something similar ?
