Okay then chaps. Quick brainpick. Decided to shift the Gypsy onto the drive, to fnd that the clutch and brake master cylinders are well and truly stuck solid. Have a spare cylinder, (my hoarding does come in useful),
that's going onto the clutch, and have disassembled what was the clutch one, (have a nice dent in the fire surround now, thanks to the airline and the cylinder piston),
and just wanted to check. Seals appear okay, but would I be best off replacing them and the spring, just for good measure, or just reassemble as is and pop back in?
Edit: Btw, they are the old Girling 3/4's, so I assume parts should still be readily available if needed?
