Hi all, i've decided to do a 2" body lift mainly for the upcoming intercooler fit, the nylon blocks i have had made by a friend at work and are 50mm tall x 50mm diameter, 10 of, with, at the moment a 10mm hole down the middle, no problems there.
The 4 radiator drop brackets 85mm x 35mm, but what size holes and how thick? 2mm? do i weld nuts on the back to make life easier and what size nuts?
Bumper/Bull bar drop brackets, i've seen on the tech sit that they have been done with a small drom bracket on one bolt, surly both bolts should be refitted, would a 150mm x 100mm 5mm thick plate be better?
And finally, mounting bolts, i have in my posetion quite a few m14 fin thread 130mm engine mounting bolts, could these be utalised or am i better off with m10, the only m10 i have is stainless steel threaded bar, would that do? also found some m12 x 120mm high tensile
Sorry but i'm a tight git and dont like buying what i have or could use
as you know more about these trucks then me, so really the only way to know if the rad needs lowering is to do the lifts and then lower the bonnet and see if it catches the rad cap or not then you'll know for for sure yourself.
