its three images, resized to match (ish) at the wheel centres, made into an animated gif in ImageReady (adobe, stablemate of photoshop) with a blend between them.
just with them being to big for the upper seat I wondered if the MOT man had anything to say about it.
I have. Failed first time as they weren't sitting in the cups properly. I took them home, re-seated them, and he passed them. Did advise that I should try and get bigger cups if possible as the originals are a tad too small really.
Cheers for the replies chaps I already have OME +2" but they are a bit tired after 3 years of use. The downside is they are about £58 each spring to replace!
Two MOTs on LC springs, no problems. No shock rubbing either. If I was to be critical I'd say they are too firm for an unloaded truck, but when you load it up, they are perfect.
