last week i had the head pulled off my truck because there was a suspect issue with a valve. turns out it wasnt a problem with that, and it was just the shims but anyway my loss...
tonight is the first time ive taken it out on a long run, i picked up a lady friend and we went down to brighton. truck is fine, except a couple of things.
front heater was working fine, until i turned it to cold, and then i couldnt get it back over to hot because i suspect a kink in the cable.
rear heater is fine. but i noticed that it gets cooler if you are at traffic lights or are just stopped. but then if you floor it it gets red / burn hot as it usually does.
i was trying to work this out..
but then, we drove back from brighton, temp on the gauge never moved off just before half way, i was always checking just in case like.
i drop her off, and just as im about to pull away i look at the gauge and its all of a sudden at 3/4 mark. i go into brown mode, and decide the best thing to do is get moving for air flow.
earlier in the night i noticed the electric fan on but the temp on the gauge was still half way so didnt pay too much attention to it.
so now when im stopped at lights the rear heater turns to ice cold, but then if i revv it the temp gauge shoots up to 3/4. then if i keep it revved it goes back to dead on half way and the heater goes red hot again..
what the hell is going on? do i have an air lock or something?
when i got the truck back i left the rad cap off for a whole 24 hours to be doubly sure of air locks.
the water expansion bottle has not yet bubbled over but i also filled this up almost to the brim in case any air was let out and was replaced with water.
there is a slight wirring noise, sounds a bit like a belt on too tight but its hardly noticeable. is the water pump driven off a belt? and could this be slipping as this would explain if i revved it then the heater gets hot and the engine gets cool..
you dont understand how rubbish i feel now. ive just paid £600 to get my truck back in a worse condition
any help much appreciated. plumb_bob - what did i tell ya
