Rear Window Stuck
  • Rear Window Stuck
    Hi,
    Got an M reg surf and the rear window has seized, I can hear the motor running but the Window requires assistance to go down and up any ideas on fixing the problem.
    Cheers.
    its knackered im afraid, need to scrap the truck !
      wind it right down, keep heaters on full blast and forget about it...
      or, by some silicone lubricant stuff from a factors place, spray the rubbers/runner thingy that window goes up in and wind up window and down again until it goes better...rinse and repeat (without the rinse bit unless your a qualified 3rd genner)
      if this still hasn't fixed it, undo backing to mechanism motor thing and grease moving stuff...if it still don't work then the head's gone.
        what heads gone?
          The plastic disc are knackered you require a new motor from ebay about £40
          and a £10 blue membership star
          I got one
          www.cnpbetterhomes.co.uk
            you will find absolutely everything you need to know about your problem using the search function
              lets all put the new bloke off then huh !!!
              mate dont listen to any of the replies above
              press the red button by the gearshift,and dont let yoshie see you post without a blue star.
              (seriously use the search function it will point you in the right direction)
              Non intercooled nothing.
                [QUOTE=gwh200;417282]
                QUOTE]
                anduyd what was wrong with my reply? may be drunk but know there was some advice in there.
                  [quote=logey79;417283]
                  QUOTE]
                  there was GOOD advice in ther,just for another surf!!
                    The newbie gets a few weeks grace and will e happy to pay whe he fixes his window and realises how helpful the seach button is. But white akita it's that you ave no Star.
                    Pay up tight wad
                    Brian
                      Originally posted by warsurf View Post
                      Hi,
                      Cheers.
                      ya window motor is going mate mine did the same then it packed in all togeather
                      you may need a new one you will have to have a look at it
                        I got one
                        have i had to much to drink or did i not cover all this without leadin him down the garden path
                          my truck might possibly be sold in the next 2 weeks so dont really want to pay for a years membership.
                            Buy another you know you will only miss it
                            Brian
