Picture Please!!!!
  • Picture Please!!!!
    Can anyone post a decent pic of the adjuster bolt arrangement on the alternator of a 2.4 tdi.
    Ive taken the battery off, the washer bottle out and undone and raised the A/C pump out of the way. got the pivot bolt out of the alternator, now need to get an EASYOUT from my mate in the morning then i can get the broken bolt out and start putting things back!!
    Trouble is the top bolt has sheared off resulting in the alternator adjuster falling to bits, so i dont know how it should go back together!!!
    All help gratefully received!!
    thanks
    Alan
    BUMP !!!!!
    Can anyone do a quick pic on thier phone or anything in the morning!!
      hey alan,give me about half an hour and i will go get one
      Non intercooled nothing.
        did you get the wheels ?
          hi mate,
          called the people and have to call back on monday to arrange delivrry
          cheers
            here we are alan,
            the long bolt does the adjusting,and the block it passes through,needs to be attached to the alternator
              Spot on mate!
              Thats all i needed to see. Hopefully now when the parts turn up i'll be able to slap it all back together no probs!
              Thanks for the very generous offer mate! Truly appreciated.
              Alan
                u appear to have things growing in there!
                  its well easy to do mate.did my timing belt today so i put new belts on allround.i had to undo the bolt passing through the block and you can then adjust the alternator with the long bolt.any probs mate and let me know i can be there in a flash
                    salisbury plain 28th december 2007,still picking grass and mud out of all nooks and crannys
                      This is how mine looked before i hoisted the a/c pump up out of the way!
                        BDT2......... yes Andy that is mud INSIDE the engine bay, stillthere from nov 25th laning!!!!!
                        The square adjuster block and the other half of the alternator bolt were found on top of the air con rad, and there was no nut on the long pivot bolt that holds the alternator on!!!
                        Alan
                          looks suspiciously clean to me,but then im still scraping salisbury plains mud off now !!
                            tintin is that a peice bonding earth(household) cable i see?lolol
                              Yes mate, its just a temp earth to the spots on the A bar, so i could check them out.
                              Will get some black cable and route it neatly in the next couple of weeks!
                              (if i can afford it, need two front tyres desperately!!)
                              Alan
