L/C Springs And Torsion Crank Pics. Def Need My 33's Now
    Ah yes but grey is for gay!!!!! Sorry Brian....... But it is
    Without Surf And Unhappy
      Originally posted by Scorpion View Post
      There's a grey one on Ebay at the minute.
      http://cgi.ebay.co.uk/Toyota-Hi-Lux-...QQcmdZViewItem
      He's hoping..................
      Rob
      Still working for the man!
        Tell it to Alan mine is Blue
        Brian
          Hahahaha, sorry Alan, your grey is gay
            However after test fitting his new wing today I'm sorely tempted to get mine painted matt black
            Brian
              matt black was a thought of mine some time ago. Easy, home job and cheap
                Yep matt black with orange shock boots good redneck look
                Brian
                  Only problem is after a while matt black starts to come off dusty and turn a bit grey, also birds mess if left can stain it more as i found it porous
                  • #24
                    Better stop now, if Alan reads this he will get the paint oot when I'm no here
                    Brian
                    • #25
                      BTW, the L/C springs took 4 spring commpressors to get em in, and i had to lever them in wiv a crow bar aswell, and that was wiv shocks off and wheel off and jacked up to the flippin sky.
                      • #26
                        Discussed this with Alan today springs do look monsters thought four per spring would be better
                        Brian
                        • #27
                          Only took me an hour to do the 2. It is fiddly but relatively easy. As with alot of l/c runners on here one of mine touches the shock, smiffys are the same, but ive been driving about and they are perfect, even in extremes.
                          • #28
                            Yep I was asking Andy and Rich the other day Andy says I will need the es9000 I have on order if I value my spine
                            Brian
                            • #29
                              The passenger side spring can be fitted without compressors.
                              On the drivers side, unbolt the top control arm from the axle so that that the axle can be pushed down without the control arm hitting the fuel tank.
                              When both springs are in, re-fit wheels and lower tuck down so that the control arm bolt can be re-fitted.
                              I fitted Apaches without using spring compressors.
                              • #30
                                well im gonna be knockin my pan in on es 3000's for the foreseeable now, no more mod money left for a bit
