recommended glow plugs
  • recommended glow plugs
    hi this is my first post on here. I've got a 1992 2.4 ssrx surf and i've been having some starting problems with it for a while. It appears to be that the plugs are nackerd although there only about 1 year old. Can anyone one recommend a good set of glow plugs as the last one i put in were the cheapest i could find and don't seem to have lasted. Thanks in advance
    Hi mate, and welcome - I would advise against saving money by buying cheap glow plugs, go to your local main stealer and get some from them - you'll be glad you did!
      Hiya Sam welcome to the madhouse and good to see another cornish surfer here.Try www.roughtrax.com
      Where in this wonderful county are you
        What he said.
        Fitted mine about 3 weeks ago and it turns over first time every time.
        If your having issues check the 80 amp fuse in the fuse box before you attack the glow plugs matey.
        Tequilla - breakfast of heros.
          As MudSurfer mentioned, go to the local dealer. They are actually quite good on prices as a rule for mech parts. It's cosmetics where they tend to screw you, money wise.
            Thanks for the welcome and replies. I thought getting plugs from a dealer would be the best option but i was quoted about £70 for them. i probably will get originals from the dealer but i have seen these on ebay and wondered if anyone knew if these were any good. There NGK ones and know there spark plugs are usaully pretty good so may give them a try as there a bit cheaper.
            http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=002
            if this link dosen't work the item number is 120217314911.
              Hi mate thanks for the welcome. I'm just down the road, i live in Hayle
                Hi Sam.I am off work for the rest of this week so if you need a hand or anything give me a shout.I am hoping to get a breaker this week so if you need some spares keep an eye in the parts for sale section
                  Make sure you have your spare nut and bolt set with you then Richard.
                    thats ok Matt cause if i get the breaker there 'll be plenty of spares
                      nice one mate. may well take you up on that.
                        Keep an eye open for this truck Sam.As far as i know its the only lifted black truck around here, i am normally driving around all over the place anyway
                          I'll keep an open for you. Mines J reg, green with four spotlights on the front and large dent on drivers side rear panel. You won't see mine on the road at the moment should be about shortly.
                            There's a few of us that go off roading and laning if your interested any time
                              yeh always up for a bit of off roading. Just got to get it back on the road and I'll be up for it.
