noticed some rear sag on my 3l 4runner especially drivers/tank side.
Looking to replace with new so assuming I am not to fussed about adding a lift could someone answere the following couple of questions:
1) Is there an idiots guide
2) Milners springs or roughtrax (15% more expensive)
3) do you need to drain and disconnect brake system
4) can get hold of spring compressors are these required or will they help?
I know there are a few links already on here but there is some confusion as some talk about disconnecting brakes otheres indicate its not required.
Should there be a noticeable improvement in handling?
thanks guys
thanks guys
